BaconLettuceNinja wrote:Every time I try to export data to GP2, it says 'GP2.exe was not patched correctly'...anyone know how to fix this?
Thanks in advance
![Smile :)](./images/smilies/icon_e_smile.gif)
Fixed now.
Ok, the engines are all sorted now, as all of the remaining teams will use VW powerplants. As Wizzie raised some concern over power difference, the engine is less of a hinderance in the race than before so there's less reason for concern.
Calendar-wise, I'll take Lappy up on his suggestion to make a couple of races support races...not sure what races these will be yet. I'll make it a 10-race calendar, if there's a grid tool for GP2 kicking around somewhere I can perhaps add sprint races. Due to the low power nature of the cars, races will be around 25% of the original distance.
Two pre-season tests will take place at Jerez and Estoril once drivers are confirmed and liveries are complete.
And Ferrarist, as you finalised your entry after eurobrun you're now first on the waiting list should any places become available. Your drivers were made available for other teams; if this isn't ok then I'll pull them out. Otherwise, Hwok Kwol-Cho will continue on at V-Sport.
Unless anyone has any objections, I'll make Jari Lappalainen, the 18-year-old Finn who is currently Fusion's tester in RoLFS, available for anyone to take on.
