F1RMGP 2015: the Women's European Cup v2.0
- dinizintheoven
"So... I wonder if anyone can beat me this year?"
Never fear, dr-baker and others, the F1RMGP Women's European Cup is back for a second season, and better still, the calendar's expanded to 12 rounds in 12 different countries. The first season, as you'll all know, was very much a dry run for an all-new F1RMGP setup, and served its purpose adequately (in the end). And it seems so many of you have got a taste for running your own F1RMGP teams (not just you, Mr Lindsay) that it's only fair to run this championship again, before the Bathurst Enduro closes the season where all the F1RWRS/GP2C/REECCS (etc) drivers can join in the fun as well. With most of the teething troubles of the first season ironed out, this second season will be run in much the same way as the 2014 Bathurst Enduro was, so, here's how it will work.
The points and garages system
There will be fourteen garages available this year, and hence, fourteen teams. As with the Bathurst Enduro, the number of points will be highest in garage 1, and lowest in garage 14. Not all the 2014 cars will be available, but all are rated out of 100 for both power and reliability, with the ratings given as they were at the end of the 2014 season - some cars were developed on the way, most weren't. Likewise, drivers are rated out of 100 for both skill and consistency, and the ratings are given as they were at the end of the WEC season, or - in a few cases - at the beginning of the Bathurst Enduro (which is those who did not compete in the WEC season but were rated for the Enduro in case any of them happened to be selected). A small extra rating for the car called the "qualifying boost" is rated from -10 to +10; this also counts to the total, so a theoretically "perfect" team would score 610 points. However, a qualifying boost of 0 does not necessarily mean the qualifying pace is the same as the race pace, and only the Series Management knows how any of these ratings translate to the cars' and drivers' performance.
There is no obligation to use all the points available to each garage, but it is strongly recommended. As it was at Bathurst, each car-and-drivers combination can be adjusted to the correct number of points by tweaking the car - whether that's improving it or throwing a spanner in the works - and likewise, drivers can be given a bit of extra training or "hindered" somewhat.
This is important:
- Car power and reliability ratings cannot be adjusted by more than 20 points each way.
- Driver skill and consistency ratings cannot be adjusted by more than 10 points each way.
- No rating can be adjusted to more than 100 or less than 0, except for:
- the qualifying boost which can be adjusted by a maximum of 4 points from its original value, to a maximum of +10 and a minimum of -10.
A maximum of two hologrammatic drivers are available, as the Main Series has none. However, as Günther Schmidt is still in charge at ATS Rial, no hologrammatic team bosses will be able to participate.
The entry procedure
Slots on the grid will be allocated in the order of who posts first, and according to what car is being used, and - crucially (said Jonathan Legard) - whether or not the entry is complete and correct. A complete entry consists of:
- the garage number
- a team name; this can be one of the teams that participated last year, or a completely new team, but each entry will be named this year, there won't just be "(Main Series team name) WEC".
- one or more team principals: these are optional and will default to those of the Main Series if none are given.
- the car numbers; these need to be consecutive, anywhere from 3 to 99 and there are no leading zeroes (like in America, where "7" and "07" are different cars). The numbers 1 and 2 are reserved for Vanina Ickx and her team-mate (if she gets entered at all to defend her title) so that also rules out the number 0. And, also, numbers 9 and 10 are reserved for the "competition" garage - see below in the Entrants section.
- the 2014 chassis, complete with acknowledgement of the base P/R ratings, and any adjustments (max P/R ±20, QB ±4).
- the two drivers, also complete with acknowledgement of base S/C ratings, and any adjustments (max S/C ±10). Any drivers who are not so far listed - give them stats that are appropriate (i.e. nobody with the ineptitude of Milka Duno should be made to look like Michèle Mouton).
- add up the total points to show that they're appropriate for that garage, and include this in the entry.
Additional driver restrictions:
- this series, as you'll all have twigged (unless you're FMecha) is for real life drivers only. There are plenty of F1 Rejects Universe series for the Katayama sisters (and others) to compete in!
- the Cope twins will only race as a pair in the same team, though it might be interesting to see what happens if they're trained differently. They have the same base S/C ratings.
This is important, so I'll say it again: entries will not be accepted until they're complete and correct. So be very careful adding up those stats, because if you're overdrawn, the entry will not be accepted and another forumite can come in and steal the place you were looking for.
And just so there's no hogging the grid, one team per forum member, unless we're running close to the deadline and it looks like there will be no further entries (say, with about three days to kick-off).
The race weekend
There will be one qualifying session - and with 14 teams, hence 28 cars competing for 26 grid slots, you know what that means - there'll be a guaranteed two DNQs every time. Hence, the 107% rule has been ditched, and will only be reinstated if more than three drivers prove to be so slow - and we're talking 1991-vintage Coloni slow here - that it's worth reinstating.
The race takes place over the same distance as it does in the Main Series, the day before - and results will be posted at the same time as the Main Series, which will be on approximately a weekly schedule.
The quest for the Maria Terese de Filippis and Bertha Benz Cups begins here!
James Allen, on his favourite F1 engine of all time:
"...the Life W12, I can't describe the noise to you, but imagine filling your dustbin with nuts and bolts, and then throwing it down the stairs, it was something akin to that!"
- dinizintheoven
Re: F1RMGP 2015: the Women's European Cup v2.0
ENTRANTS
(this will be updated as the entries are submitted correctly)
The entry list will OPEN when the first testing times from the current F1RMGP are posted, AND NOT BEFORE - entries submitted before this point will be null and void!
The entry list will CLOSE when the report of the F1RMGP Canadian Grand Prix is published - this is the third race of the season - or when all 14 garages are correctly filled.
The WEC season starts at the F1RMGP Monaco Grand Prix, the fourth round of the Main Series season, and lasts for 12 rounds.
GARAGE: VR
TEAM NAME: Scuderia Alitaliana
TEAM PRINCPALS: Aladsair Lindsay
FORUM MANAGER: kostas22
CHASSIS: Viking MJØLNER-03
DRIVER: 1 - Vanina Ickx
DRIVER: 2 - Michèle Mouton
This is the "competition" garage. It is available to the first forum member who can correctly identify the significance of Þorvaldur Einarsson's date of birth (it's given on the wiki, and also on the 2015 Main Series forum thread). With this garage comes the exclusive use of the Viking MJØLNER-03 (rated P80/R90, the strongest car in the 2014 F1RMGP season) and the chance to get a massive advantage over the rest!
A word of warning, though: the right to use this car can be withdrawn if the Forum Manager is seen to be "bringing the team into disrepute" - this team don't muck about with their axes, remember...
EDIT: a second competition garage should be made available in the near(ish) future...
GARAGE: LH
TEAM NAME:
TEAM PRINCPAL(S):
FORUM MANAGER:
CHASSIS: Leyton House LHS/CG141
DRIVER:
DRIVER:
GARAGE: 1
TEAM NAME: Restov Racing
TEAM PRINCPALS: Edward Restov
FORUM MANAGER: takagi_for_the_win
CHASSIS: Super Aguri SA14
DRIVER: 5 - Danica Patrick
DRIVER: 6 - Nettan Lindgren
GARAGE: 2
TEAM NAME: SonicSport
TEAM PRINCPALS: Phil Erup
FORUM MANAGER: tristan1117
CHASSIS: ATS Rial ARC-5
DRIVER: 39 - Susie Wolff
DRIVER: 40 - Divina Galica
GARAGE: 3
TEAM NAME: Autodynamics Simtek GP
TEAM PRINCPALS: Nick Wirth, Jörg Scrattenheim
FORUM MANAGER: eurobrun
CHASSIS: Simtek S141
DRIVER: 3 - Jutta Kleinschmidt
DRIVER: 4 - Simona de Silvestro
GARAGE: 4
TEAM NAME: Shell JLD Motorsport
TEAM PRINCPAL: Pierre Depault
FORUM MANAGER: Wizzie
CHASSIS: F1RM F1R-14
DRIVER: 16 - Sabine Schmitz
DRIVER: 17 - Junko Mihara
GARAGE: 5
TEAM NAME: Scuderia Minardivas
TEAM PRINCPAL: Elio di Rupo
FORUM MANAGER: This
CHASSIS: Forti FG07
DRIVER: 23 - Lella Lombardi (H)
DRIVER: 24 - Giovanna Amati
GARAGE: 6
TEAM NAME: West Cliff Racing
TEAM PRINCPAL: Pippa Mann of the F1 Rejects universe
FORUM MANAGER: dr-baker
CHASSIS: SPAM PD-12
DRIVER: 7 - Alice Powell
DRIVER: 8 - Pippa Cow
GARAGE: 7
TEAM NAME: Super Reppu!
TEAM PRINCPAL: Mika Salo
FORUM MANAGER: SuperAguri
CHASSIS: Dome Do14
DRIVER: 87 - Keiko Ihara
DRIVER: 88 - Yuri Mitsui
GARAGE: 8
TEAM NAME: Cope-ersucar
TEAM PRINCPAL: Gerald Pereira
FORUM MANAGER: WaffleCat
CHASSIS: Spyker F12-XIV
DRIVER: 14 - Amber Cope
DRIVER: 15 - Angela Cope
GARAGE: 9
TEAM NAME: Foster's Good Women with Plus One
TEAM PRINCPAL: Luke Knight
FORUM MANAGER: pasta_maldonado
CHASSIS: Scuderia Andrea Coloni SAC8
DRIVER: 77 - Cyndie Allemann
DRIVER: 78 - Kazumi Mikami
GARAGE: 10
TEAM NAME: Team Australia
TEAM PRINCPAL: Craig Gore
FORUM MANAGER: Grovey
CHASSIS: Monteverdi ORE-6
DRIVER: 90 - Leanne Tander
DRIVER: 91 - Samantha Reid
GARAGE: 11
TEAM NAME: Filles Sur Roues
TEAM PRINCPAL: Sophie Fabron
FORUM MANAGER: Nuppiz
CHASSIS: Stefan S-04
DRIVER: 54 - Rahel Frey
DRIVER: 55 - Vicky Piria
GARAGE: 12
TEAM NAME: Psycho Soldiers
TEAM PRINCPAL: Ai
FORUM MANAGER: FMecha
CHASSIS: David Price DPR-1
DRIVER: 97 - Pippa Mann (of the real universe)
DRIVER: 98 - Katherine Legge
GARAGE: 14
TEAM NAME: Rosenforth Engineering
TEAM PRINCPALS: Jimmy Rosenforth, John Zimmer
FORUM MANAGER: the Masked Lapwing
CHASSIS: Minardi PS09
DRIVER: 10 - Emma Kimiläinen
DRIVER: 11 - Karen Andrews
THE ENTRY LIST IS FULL - unless there is significant extra interest in forming a pre-qualifying round and having extra cars from the 2013 season.
GARAGE: VR
GARAGE: LH
TEAM NAME:
TEAM PRINCPAL(S):
FORUM MANAGER:
DRIVER:
DRIVER:
GARAGE: 1
GARAGE: 2
GARAGE: 3
GARAGE: 4
GARAGE: 5
FORUM MANAGER: This
CHASSIS: Forti FG07
GARAGE: 6
CHASSIS: SPAM PD-12
GARAGE: 7
CHASSIS: Dome Do14
GARAGE: 8
GARAGE: 9
GARAGE: 10
GARAGE: 11
GARAGE: 12
TEAM PRINCPAL: Ai
GARAGE: 14
- dinizintheoven
CAR RATINGS
Any chassis marked with an asterisk is (as you should all know) a team that has pulled out of F1RMGP for 2015, and will send only a skeleton crew to the WEC races this year if called on to do so. This may have an effect on performance as the season goes on...
DRIVER RATINGS
Something to bear in mind here is that nobody who competed in Formula Woman can ever be rated higher than 93 or lower than 36. That series was a joke. This isn't.
This should be all the information that is needed to get the entries in - once the entry list opens. Is it, or isn't it? Any questions, get posting.
CHASSIS POW REL QB TOTAL
Viking MJØLNER-03 80 90 +2 172 - only available via the competition garage, a competition which kostas22 has already won within a few minutes of this thread being posted...
Leyton House LHS/CG141 88 78 0 166 - chassis now available to anyone who can answer the second ("thorcast") competition!
F1RM F1R-14 64 87 +2 153
SPAM PD-12 72 84 -4 152
Simtek S141 62 90 0 152
ATS Rial ARC-5 72 78 -4 146
Super Aguri SA14 72 73 0 145
Forti FG07 68 70 +2 140
EuroBrun ER214* 62 74 0 136
AGS JH31 58 75 0 133
Sc. Andrea Coloni SAC8 58 69 0 127
Toleman TG214* 60 60 0 120
Dome Do14 62 57 0 119
Monteverdi ORE-6* 60 48 0 108
Spyker F12-XIV 62 38 +4 104
Stefan S-04 54 28 +2 84
David Price DPR-1* 28 51 0 79
Minardi PS09 36 37 +2 75
Genii T. Malaysia GEN-4* 32 16 0 48
DRIVER RATINGS
DRIVER SKL CON TOTAL
Michèle Mouton 65 67 132
Sabine Schmitz 69 61 130
Ramona Karlsson 68 61 129
Alice Powell 63 64 127
Nettan Lindgren 52 69 121
Vanina Ickx 56 64 120
Danica Patrick 60 58 118
Sarah Fisher 55 63 118
Emma Kimiläinen 57 58 115
Simona de Silvestro 60 53 113
Ana Beatriz 58 54 112
Divina Galica 60 51 111
Natacha Gachnang 52 56 108
Susie Wolff 57 48 105
Rahel Frey 58 46 104
Amber Cope 54 48 102
Angela Cope 54 48 102
Lella Lombardi (H) 64 35 99
Cyndie Allemann 51 47 98
Jutta Kleinschmidt 59 36 95
Natasha Firman 39 54 93
Keiko Ihara 55 36 91
Katherine Legge 56 34 90
Pippa Mann 55 32 87
Michele Bumgarner 31 53 84
Giovanna Amati 32 52 84
Milka Duno 31 48 79
Yuri Mitsui 35 43 78
Kazumi Mikami 41 30 71
Junko Mihara 31 32 63
Pippa Cow 26 25 51
Karen Andrews 17 19 36
- DemocalypseNow
- Contact:
I'm going to have a guess at the VIKING garage. Is it because it was the release date of Reign in Blood by Slayer, the album that made them well known internationally?
- dinizintheoven
kostas22 wrote:I'm going to have a guess at the VIKING garage. Is it because it was the release date of Reign in Blood by Slayer, the album that made them well known internationally?
Got it in one.
The padlock's just been taken off Garage VR... use it wisely.
- dinizintheoven
...I wasn't expecting anyone to get that, either. I'll have to think of another really hard riddle to open up Garage LH with - meanwhile, I'll threaten the Suzuki management with a large crowbar and demand they make the LHS/CG141 available. This championship could be a foregone conclusion otherwise, and we don't want that, do we?
What's that, Vanina? You do? Again? Shut it.
- dinizintheoven
Crowbar applied. Your clue is "thorcast"; using this clue word, tell me what links Borknagar and Achren with the Leyton House LHS/CG141. Do that, and you'll get access to the most powerful of the 2014 cars.
- DemocalypseNow
- Contact:
Scuderia Alitaliana (see what I did there? Yeah, I think you did)
One // Vanina Ickx
Two // Michèle Mouton
Team Principal // Alasdair Lindsay
Forum Manager // kostas22
Our remaining six points will be added to the chassis' power rating.
One // Vanina Ickx
- RonDenisDeletraz
- Contact:
Could you please save a spot for me, I probably won't be on a computer until tomorrow.
aerond wrote:Yes RDD, but we always knew you never had any sort of taste either
tommykl wrote:I have a shite car and meme sponsors, but Corrado Fabi will carry me to the promised land with the power of Lionel Richie.
- dinizintheoven
...and I won't be posting the testing times until tomorrow at least (that same clue word that will allow access to garage LH is the reason why), probably the day after, so there's no chance of the entry list opening until then. Those worried what kostas is doing there, I assume this means a clear intention to take up the option of garage VR (it's not actually compulsory, just a huge advantage, and the same applies to garage LH). But I'm not going to close garage 14 - maybe there's someone out there who wants to be the reject of the series. Maybe garage 1 will be the one left over, though I doubt it. Either way, one garage will be left empty. Maybe two - those of you who want to claw back some competitiveness should take the clue word, do your research and find out what in bathroomsinkplug's name I am talking about. It'll be obvious when you see it, though.
Those worried that this series will already be a foregone conclusion need not do so. There's one extra variable that I have said nothing about, nor will I do so, regardless of the amount of prompting I am given.
Is it possible that you could give some possible stats for Helle Nice, Maria Teresa de Fillipis and Desire Wilson, for consideration purposes please? I understand that a maximum of two Hologrammatic drivers are permitted...
MCard LOLAdinizintheoven wrote:GOOD CHRISTIANS do not go to jail. EVERYONE ON FORMULA ONE REJECTS should be in jail.
- dinizintheoven
Hellé Nice I'm really not sure I could come up with anything for - I was unfamiliar with the name, and I find she was a pre-war driver! I would suggest, if you want to run her in any series, do what I did with Tazio Nuvolari and enter her in the 1952 season of "We Recreate Reality". If it's still going. And if it isn't, give tommykl a kick and see if he'll hand over the running.
Maria Teresa de Filippis, as you haven't twigged yet (but probably should have done given how the Main Series ended in 2014) will be the one presenting the cup bearing her name at the end of the series, so it's hardly fair to have her driving! Plus, would you unleash an 89-year-old amongst this field?
Desiré Wilson, though - she may be getting on a bit (61, by the start of this championship) - but that's about the upper age limit for the drivers in the Main Series (i.e. Philippe Alliot and Eliseo Salazar), and I think she could teach these young whippersnappers (yes, Miss Powell, that means you) a thing or two. I'm actually surprised she wasn't entered for the first WEC season. Given her performance in the Aurora AFX series, in which she took Divina Galica to the cleaners, I'll give her S65/C59 for a total of 124. Team her with a wise choice of chassis, if that is your intention.
EDIT: ye gods. Divina has hit 70 in this universe. Was that 2014 WEC outing a last burst of speed before taking up knitting and bingo on a permanent basis?
dinizintheoven wrote:Hellé Nice I'm really not sure I could come up with anything for - I was unfamiliar with the name, and I find she was a pre-war driver! I would suggest, if you want to run her in any series, do what I did with Tazio Nuvolari and enter her in the 1952 season of "We Recreate Reality". If it's still going. And if it isn't, give tommykl a kick and see if he'll hand over the running.
All fair enough. Thank you. And I already have my plans for my team drawn up. Could you give a one- onr two-hour window in which you are likely to open up the entries, or do I have to be at my computer regularly checking all day?
You can add Vicky Piria and Carmen Jorda to the stats, as they are up-and-coming, eh... talents, from the F2.
I don't know what i want and i want it now!
- DemocalypseNow
- Contact:
This wrote:You can add Vicky Piria and Carmen Jorda to the stats, as they are up-and-coming, eh... talents, from the F2.
Talent? Yes, I think this word is appropriate...
- tristan1117
- Site Donor
I'm going to take a wild stab at the "thorcast" riddle. Borknagar and Achren are European metal bands which heavily use guitars. One of the most famous guitars in production is the Fender Stratocaster. Arguably the most used method in teaching guitar is the "Suzuki" method, which obviously links to the engine in the back of the Leyton House. The "thor" in thorcast comes from Viking influences on Borknagar and the "cast" comes from the guitar. It's so ridiculously convoluted that it may just be right. After all, when you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth. (courtesy of Sherlock Holmes).
CoopsII wrote:On occasion I have ventured into the PMM forum but beat a hasty retreat soon after as it resembles some sort of bad acid trip in there
- dinizintheoven
tristan1117 wrote:I'm going to take a wild stab at the "thorcast" riddle. Borknagar and Achren are European metal bands which heavily use guitars. One of the most famous guitars in production is the Fender Stratocaster. Arguably the most used method in teaching guitar is the "Suzuki" method, which obviously links to the engine in the back of the Leyton House. The "thor" in thorcast comes from Viking influences on Borknagar and the "cast" comes from the guitar. It's so ridiculously convoluted that it may just be right. After all, when you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth. (courtesy of Sherlock Holmes).
It's a quite brilliant explanation. But a whole universe away from what I was thinking. Stick "thorcast" into Google and you'll all be closer. I think this one was too hard as it stands...!
Incidentally, it'll be Sunday at the very least before there's any Main Series testing times, hence the entry list won't open until then, but be thinking about your team configurations...
dinizintheoven wrote:tristan1117 wrote:I'm going to take a wild stab at the "thorcast" riddle. Borknagar and Achren are European metal bands which heavily use guitars. One of the most famous guitars in production is the Fender Stratocaster. Arguably the most used method in teaching guitar is the "Suzuki" method, which obviously links to the engine in the back of the Leyton House. The "thor" in thorcast comes from Viking influences on Borknagar and the "cast" comes from the guitar. It's so ridiculously convoluted that it may just be right. After all, when you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth. (courtesy of Sherlock Holmes).
I think I've got it! Thorcast is a local Canadian business. The Leyton House team in 1990 had very few sponsors that year. In the lead-up to the Canadian GP, they featured in a newspaper interview in the country, and managed to obtain a large number of one-off sponsors for the event, one of whom may or may not have been this local Canadian business!
- dinizintheoven
dr-baker wrote:I think I've got it! Thorcast is a local Canadian business. The Leyton House team in 1990 had very few sponsors that year. In the lead-up to the Canadian GP, they featured in a newspaper interview in the country, and managed to obtain a large number of one-off sponsors for the event, one of whom may or may not have been this local Canadian business!
Oh, yes, them. The ones who took the URL I wanted.
There's your second clue. And on that note, the Main Series is about to go testing at Imola. Watch that thread.
YES! Nothing has happened overnight! I thought I must have missed my chance by now. Here's hoping I don't miss my chances between lectures, assignment writing, seminars, socialising, etc.!
- dinizintheoven
The entry list is now open!
With the padlock coming off garage VR (and being taken by Scuderia Alitaliana), there are 13 entries still available - each one must specify which garage they're going for, with its concomitant points total. One numbered garage will be left over. Garage LH will be available to anyone who solves the "thorcast" mystery (and it's probably easier than you'd think, plus I've dropped a big hint on another forum), but: if this garage goes unclaimed when the other 13 are filled, and the mystery is solved before the results of the Canadian Grand Prix are published (the round before the WEC is due to start), then the manager of that garage can trade their car for the Leyton House, no questions asked - though it might well be too late in the season to modify it. Not that it really needs modifying with all that power.
Get the entries in! And make sure they're correct, add up those points well - don't lose the place you want!
- takagi_for_the_win
Erm, hate to sound like a total noob, but is it free for ANYONE to enter? I am interested in this, but I'm not sure if you need to be in the F1RWRS or whatever.
TORA! TORA! TORA!
- dinizintheoven
takagi_for_the_win wrote:Erm, hate to sound like a total noob, but is it free for ANYONE to enter? I am interested in this, but I'm not sure if you need to be in the F1RWRS or whatever.
Absolutely anyone can - F1RMGP is not intertwined with the hierarchy of F1/2/3RWRS or any other F1 Rejects competition, except when the Bathurst Enduro comes round and all those other-universe drivers join in to see who's best. So, you want in on this one... go for it, while you still can!
My entry
Garage number- 1
Team name- Restov Racing
Team Principal- Edward Restov
Car numbers- 5, 6
2014 chassis- Super Aguri SA14 (P-72, R-73, QB-0)
Drivers- Danica Patrick, S-60 C-58
Nettan Lindgren, S-52 C-65 (originally 69)
That adds up to 380!
Garage number- 1
Car numbers- 5, 6
TORA! TORA! TORA!
- dinizintheoven
takagi_for_the_win wrote:My entry
Garage number- 1
Car numbers- 5, 6
That it does. It's all above board: accepted!
I should also mention that if anyone wants the numbers 9 and 10, they're now available, seeing as number 1 for Vanina Ickx overrode the 9 that was originally on the Viking she'll be driving. Alternatively, why not go for a F1RMGP 2013-style 8 and 9, as F1RM did that year, or the unused 10 and 11 combination?
- tristan1117
- Site Donor
GARAGE: 2
TEAM PRINCPAL: Phil Erup
Car Numbers: 39, 40
2014 chassis: ATS Rial ARC-5 (P-73, R-80 QB,-1) )
DRIVER: Susie Wolff (S-56, R-53)
DRIVER: Divina Galica (S-59, R-50)
Total Points: 148+56+53+59+50=370
I hope this checks out.
Car Numbers: 39, 40
- dinizintheoven
tristan1117 wrote:GARAGE: 2
Car Numbers: 39, 40
2014 chassis: ATS Rial ARC-5 (P-73, R-81 QB,-1) )
DRIVER: Divina Galica (S-60, R-50)
Total Points: 149+56+53+60+50=370
It doesn't.
The ATS Rial is rated P72/R78/QB-4 for a total of 146; your adjustments are within the allowed limits to P73(+1)/R81(+3)/QB-1(+3) for a total of 153, not 149.
Susie Wolff is rated P57/R48 for a total of 105, your adjustments are P56(-1)/R53(+5) for a total of 109.
Divina Galica is rated P60/R51 for a total of 111, your adjustments are P60(0)/R50(-1) for a total of 110.
153+109+110 = 372, and that's two points overdrawn. It's not much, but you'll need to knock two off somewhere. I'll bet it's the QB that's caused the confusion... is it?
Possibly think of a second option knocking 12 points off as well, in case you're bumped down a garage.
- tristan1117
- Site Donor
dinizintheoven wrote:tristan1117 wrote:GARAGE: 2
Car Numbers: 39, 40
It doesn't.
I think I fixed it.
Formula Female Racing Malaysia(FFR-M) TEAM PRINCIPAL: Dimitri Aya(MAS)
GARAGE 4--Total points:350
CHASSIS: Simtek S141(P62+3,R90,QB0)
DRIVER 1-CAR #14:Susie Wolff(S57,C48+2)
DRIVER 2-CAR #15:Michele Bumgarner(S31+4,C53)
TOTAL-(152+3)+(84+4)+(105+2)= 350
My friend's USB drive spoiled, spilled tea on her laptop and had a bird poo in her hand.
What did she do in her past life to deserve this?
Signup for the Random Racing League, Season TWO!!!
- dinizintheoven
tristan1117 wrote:I think I fixed it.
You did. And just in time too, because...
WaffleCat wrote:DRIVER 1-CAR #14:Susie Wolff(S57,C48+2)
...WaffleCat had designs on one of your drivers!
So, Waffle, you'll have to have a slight rethink now... it's a tricky process, this, judging who was first in the queue, but tristan's "I fixed it" post was made at 2309, the edit was made at 2308, WaffleCat's post was made at 2315. It's useful, this, having timestamps on all the edited posts...
If you have to edit your teams, people, it's best to do it in a new post - it makes my life easier and makes it a lot clearer for other competitors to see everything's above board.
- RonDenisDeletraz
- Contact:
GARAGE: 3
TEAM NAME: Autodynamics Simtek GP (Yes, Autodynamics are joining this. Sort of )
TEAM PRINCPAL(S) Nick Wirth, Jorg Scrattenheim (Former F1RGP2C driver)
FORUM MANAGER: Me
DRIVER 1: Simona de Silvestro 60 53 113
DRIVER 2: Jutta Kleinschmidt 59 36 95*
CHASSIS: Simtek S141 62 90 0 152
*I would like to increase her speed and control by 6 leaving her with a rating of 107. I would also like to make the Simtek 4 points less reliable
FORUM MANAGER: Me
- the Masked Lapwing
Garage 14
Team Name: Rosenforth Engineering
Team principals: Jimmy Rosenforth, John Zimmer
Car numbers - 10, 11
Chassis: Minardi PS09 (P36, R37)
Drivers: Emma Kimilainen (S60, C53), Karen Andrews (S17, C19)
In theory:
75+36+115 = 226
which leaves 24.
So add 10 to Andrews' skill, and 14 to the Minardi's reliablity.
If I'm wrong (which I will be), I should be able to take my time
In theory:
75+36+115 = 226
which leaves 24.
R.I.P.
GM HOLDEN
1948-2017
GM HOLDEN
1948-2017
- RonDenisDeletraz
- Contact:
My numbers are 3 and 4, but de Silvestro will get the higher number despite being better
- dinizintheoven
eurobrun wrote:GARAGE: 3
FORUM MANAGER: Me
The statistics check out and add up to 360. And now that I see you've actually specified the numbers... you're in!
WaffleCat, where are you? Your team's being eaten alive...
- dinizintheoven
the Masked Lapwing wrote:Garage 14
In theory:
75+36+115 = 226
which leaves 24.
This also checks out - you're not wrong. That isn't half a step down for Emma Kimiläinen from last season, though...
Damn right i bet you Scuderia Minardivas is returning! And more Italian than ever!
GARAGE: 5
TEAM PRINCPAL(S): Elio Di Rupo (this is F1 Rejects after all...)
FORUM MANAGER: Me
CHASSIS: Forti FG07 68 70 140
DRIVER: Lella Lombardi 64 35 99
DRIVER: Giovanna Amati 32 52 84
cars 23 + 24
That should leave 17 credits free, which will be spent 9 on car power and 8 on car reliability.
GARAGE: 5
FORUM MANAGER: Me
cars 23 + 24
- dinizintheoven
This wrote:Damn right i bet you Scuderia Minardivas is returning! And more Italian than ever!
GARAGE: 5
FORUM MANAGER: Me
cars 23 + 24
Your numbers are good and you're in. Although "more Italian than ever" might be a slight fallacy, because Forti have been running as a Brazilian team in F1RMGP since its inception. And don't forget that bioethanol-burning engine from a Brazilian truck, even if this is the old turbocharged version.
- dinizintheoven
A suggestion for WaffleCat, just to put in a few hints after losing both a driver and a chassis: the SPAM PD-12 is rated the same as the Simtek, and Rahel Frey and Natascha Gachnang are similarly-rated points-wise to Susie Wolff.
This is all provided that the entry list doesn't fill up completely - which would be a lesson to everyone not to submit your team and then do a cut-and-run before it's approved...
And it may now be gone midnight, but I'm going to watch Red Dwarf. Then I'll check the thread again, go to Tesco's for some late night dinner shopping, check the thread one last time and that's it until some time in the morning. The response so far is immense.
dinizintheoven wrote:This wrote:Damn right i bet you Scuderia Minardivas is returning! And more Italian than ever!
GARAGE: 5
FORUM MANAGER: Me
cars 23 + 24
The drivers are more Italian than ever, and the team boss is slighly more Italian, so on average, it's more Italian And you forget the excellent pasta from our cook Paolo Barilla!
- dinizintheoven
This wrote:The drivers are more Italian than ever, and the team boss is slighly more Italian, so on average, it's more Italian And you forget the excellent pasta from our cook Paolo Barilla!
I suggest a cook-off. Paolo Barilla's pasta, versus Viking's mad Swedish nutters throwing mayonnaise about, versus the full curry-and-poppadoms service at Spyker. But let's not mention what's been churned out of SPAM's catering section.
