Beat Tilke at his own game
Re: Beat Tilke at his own game
Bump
in January,I decided to redevelop the entire f1 calender for this season and these are the results
Australia
http://www.gmap-pedometer.com/?r=5829795
I have built the extension which you designed and I extended the
straight from Ascari to a new hairpin which now makes for a possible
overtaking spot at Senna.
Malaysia
http://www.gmap-pedometer.com/?r=5829820
firstly, I decided to move turn 2 furthur away to try and promote
overtaking, I then added a 5th gear chicane between turns 3 and 4 on
the current circuit. I then rounded off turns 4 and 7 on the current
track before extending the run to turn 9 and rounding the tighter 2nd
apex from turn 10,the only other change I did after that was extend
the final hairpin slightly.
Bahrain
http://www.gmap-pedometer.com/?r=5829851
I started by making a flowing esse bend on the straight between turns
3 and 4 before turning my attention to the endurance layout. The
endurence layout has been made more flowing with some paribolica's,
after this the cars brake for the turn 8 hairpin which leads into the
new turn 9 which is a lot faster than it is at the moment. The next
thing I did was make turns 12,13,14 a triple apex sweeper and to end
the lap the cars bake for a more rounded off final turn.
Shanghai
http://www.gmap-pedometer.com/?r=5829884
i basically used your design for this track as i thought it was faultless
Catalunya
http://www.gmap-pedometer.com/?r=5829898
Firstly, I modified the first 2 turns to promote overtaking, then the
cars arrive at the nissan chicane which can be taken in 4th/5th gear.
Turn 10 now has a sharper entry and a more sweeping exit, then the
cars enter a new extension as they go through a sweeping s bend into a
tight hairpin before the cars go down a straight into a tight chicane
built so that the cars can go through the final 2 turns as they were
meant to be taken.
Monaco
http://www.gmap-pedometer.com/?r=5829957
The aim here was to make monaco faster and more demanding for the
drivers hence the new extension near the border with France.
Silverstone
http://www.gmap-pedometer.com/?r=5830619
I made silverstone feel more like was in the in the 1980's but with a
new loop which ends in a tight hairpin leading the cars onto the
wellington straight providing 2 new overtaking opportunities.
Hockenheim
http://www.gmap-pedometer.com/?r=5830617
The track is as per normal until turn 7 where the cars go straight on
into the driver training center for turn 8, the cars then proceed
arround the short circuit until they rejoin the gp circuit through the
stadium.
Montreal
http://www.gmap-pedometer.com/?r=5830026
I made the end of the lap more demanding by adding some fast kinks to
the back straight and just before the hairpin.
Hungaroring
http://www.gmap-pedometer.com/?r=5830084
I extended turns 1/6/14 and 15 to create 3 new overtaking
opportunities on a track famous for it's percieved lack of overtaking.
spa
http://www.gmap-pedometer.com/?r=5830695
The only 2 changes I made are the hairpin extension and the bus stop
chcane now actually resemballing a bus stop.
monza
http://www.gmap-pedometer.com/?r=5830700
The only change I made here was removing the first chicane and putting
it in just after curva grande.
singapore
http://www.gmap-pedometer.com/?r=5830701
Like shanghai, i basically coppied your design because it was perfect
but I added 1 chicane through the grandstand.
suzuka
http://www.gmap-pedometer.com/?r=5830982
The first thing I did was round off degner to make it a more flowing
corner, the next mod I did was I moved 130r closer to the wall and
making it curve a bit more before its hard on the brakes for a chicane
as the cars then go round the sweeping final curve onto the pit
straight.
korea
http://www.gmap-pedometer.com/?r=5831006
The first thing I changed was the 1.2km back straight insted making
the track curve left before the cars go into a sweeping right as the
cars join the national circuit before rejoining the gp circuit through
a sweeping left-right chicane before its hard on the bakes for turn 4,
the cars then its down a short straight into turn 5 before another
short straight into turn 6. Turns 10 and 11 have been made into a
sweeping s bend, the final mod I did was extend the straight before
turn 16 before the cars enter a hairpin before going around tuns 17
and 18.
india
http://www.gmap-pedometer.com/?r=5831017
Firstly i modified the first 2 turns to promote overtaking but the
last part is the most challenging because the cars go through a series
of sweeping esses before entering a curved braking zone into a
hairpin, the cars the go through a repilca of eau rouge on to the
current circuit.
austin
http://www.gmap-pedometer.com/?r=5831083
First of all, I modified the esses to make them a bit more flowing
than they are at the moment, next I removed the frustrating stadium
section as it really comprimises the lap in my opinion.
abu dhabi
http://www.gmap-pedometer.com/?r=5831099
Firstly, used the chicane after turn 4 to keep the flow going, after
that the cars go through turn 5 which is now a hairpin, the track
follows a short straight into the hairpin at turn 6 which is now
followed up with another short straight back onto the gp circuit.
Turn 10 has now become a hairpin which has a fast esse bend folowing
it, the final mod is the final 2 turns which have been rounded off to
create 1 sweeping turn.
interlagos
http://www.gmap-pedometer.com/?r=5831119
The cars start the lap by going around the old curva 1 and curva 2
before blasing down the retao straight, the cars then enter a tight
chicane before the old curva 3 due to the lack of run off, the cars
the follow the the old track to feradura which has been moved forward
because after that, the cars come through the sweeper at subida do
lago before its down the reta opista. Ater that there is the longer
curva do sol before the new sweeping senna s leading directey into
sargento, the cars then come around the sweeping laranja corner onto
the current track. The final mod I made is a chicane on the
arquibancadas to slow the cars for the first 2 turns.
enjoy and please comment and tell me if any thing can be done to make them better
peace Rob
Australia
Malaysia
Bahrain
Shanghai
Catalunya
meant to be taken.
Monaco
Silverstone
Hockenheim
stadium.
Montreal
Hungaroring
spa
monza
singapore
suzuka
straight.
korea
and 18.
india
current circuit.
austin
abu dhabi
interlagos
peace Rob
Mexicola wrote:shinji wrote:Mexicola wrote: I'd rather listen to a dog lick its balls. Each to their own, I guess.
Does listening to a dog licking its balls get you excited?
That's between me and my internet service provider.
One of those journalist types.
270 Tube stations in 18:42:50!
roblomas52 wrote:Monaco
The aim here was to make monaco faster and more demanding for the drivers hence the new extension near the border with France.
That would be rather steep and hilly, and possibly even rather narrow (more so than elsewhere) if my experience of Monaco (admittedly at less than an hour driving through) is anything to go by.
roblomas52 wrote:monza
The only change I made here was removing the first chicane and putting it in just after curva grande.
Assuming that it is flat out from half-way round Parabolica and all the way round Curva Granda, that's 1.5 miles and almost half the track at full throttle, probably half of which would be at 200+ mph. Can't see that happening, however much we might want it...
MCard LOLAdinizintheoven wrote:GOOD CHRISTIANS do not go to jail. EVERYONE ON FORMULA ONE REJECTS should be in jail.
this time I must praise some of your designs Rob, much more to the liking of my eye than what you have been doing previously. Especially Silverstone is good, and whilst i don't agree with half the changes, some of those ideas would work imo
when you're dead people start listening
giraurd wrote:this time I must praise some of your designs Rob, much more to the liking of my eye than what you have been doing previously. Especially Silverstone is good, and whilst i don't agree with half the changes, some of those ideas would work imo
thanks for that mate
please could you elaborate a tiny bit more on changes which should never have happened if that is ok with you
thanks
rob
I'll only mention a couple of them for now:
Monaco is good now. It's the slowest track of the calendar, which makes it unique and shouldn't be drastically changed imo; making it faster (although I don't know about the suitability of the other streets) would make it 'just another street track'.
Montreal, whilst there could be some changes, 'fast kinks' are the last corners it needs; the track's nature is start-stop chicanes with walls close, and adding any quicker corners would be against its nature.
Suzuka, Degner essentially is why the Kobayashi Hairpin exists; it lets the car behind follow close and attempt an overtake in the hairpin, thus I would keep it as it is.
Yeongam, whilst the bending straight is a nice touch, I'd not have that triple hairpin there around kilometer 3, would turn it into only one hairpin (although THAT racetrack, if any, is a victim of its site - i doubt any racetrack could be good there in that grayness, so it's kind of a lost case lol)
Austin, the first corner hill should be made use of more than in real life
giraurd wrote:I'll only mention a couple of them for now:
the back esses I did on Montreal was meant to emulate the old casino chicane used between 1978-1993
The alternative option for Yeongam is to demolish it IMO
Anyways thanks for the feed back
Peace rob
http://www.gmap-pedometer.com/?r=5844628
frankfurtring
track designed from scratch outside of frankfurt
please comment
peace rob
frankfurtring
please comment
peace rob
- HawkAussie
Some street tracks
Wellington
http://www.gmap-pedometer.com/?r=5874900
Perth
http://www.gmap-pedometer.com/?r=5874903
Wellington
Perth
Officially Retired
http://www.gmap-pedometer.com/?r=5881353
location Ta Quali, Malta
pit straight is just after the 6 km mark
tracks is mostley street but with permenant pit straight and tempory pits and grandstands
please comment
peace rob
EDIT
Melliha
http://www.gmap-pedometer.com?r=5882605
full street circuit in popular holiday town
please comment
peace rob
EDIT
Melliha
A street track I designe in Buenos Aries, near the River Plate football stadium
7.1KM
5 overtaking spots
1.3KM straight(1.8 if you add tha kinks in)
http://www.gmap-pedometer.com/?r=5923744
Please give F. E. E. D. B. A. C. K
Peace
Rob
7.1KM
5 overtaking spots
Peace
Rob
- UncreativeUsername37
roblomas52 wrote:Please give F. E. E. D. B. A. C. K
That problem's been fixed for a while now. Feedback!
- legendari25
I'm going to try that out with my own car at about 6 am next sunday, since you have to drive the wrong way in some streets
That's your best work so far. I'm glad my tip on a good location paid off
Cheers!
Cheers!
bump
some more of my better designs i have been working on latley
wembly stadium
http://www.gmap-pedometer.com/?r=5956639
city of manchester stadium
http://www.gmap-pedometer.com/?r=5958892
K.C stadium
http://www.gmap-pedometer.com/?r=5958901
Madjeski stadium
http://www.gmap-pedometer.com/?r=5958911
Madrid
http://www.gmap-pedometer.com/?r=5988578
Lisbon
http://www.gmap-pedometer.com/?r=5992445
Athens olympic park
http://www.gmap-pedometer.com/?r=6006901
Birmingham
http://www.gmap-pedometer.com/?r=6015009
London
http://www.gmap-pedometer.com/?r=6016930
harewood hillclimb
Knockhill park
http://www.gmap-pedometer.com/?r=6030132
curghbrugh sprint
http://www.gmap-pedometer.com/?r=6030843
please give feedback, good or bad
peace out
Rob
wembly stadium
K.C stadium
Madjeski stadium
Madrid
Lisbon
Athens olympic park
Birmingham
London
harewood hillclimb
Knockhill park
curghbrugh sprint
peace out
Rob
- go_Rubens
- Location: A raging river somewhere in the Eastern (cough) United States (cough)
Alright Rob, you want feedback. I will give you it.
Wembly Stadium looks good but I feel the last 2 km are a bit too convoluted of corners. The triple hairpin really is redundant and poor in one. 7 out of 10.
Manchester is okay. There are a ton of twisty bits that I am not fond of. Between kms 2 and 3 in particular. 5 out of 10.
K. C. This one has I tight section and a fast section. The way I like street courses. This is a 9 out of 10.
Madjeski is okay. The fast curving bit is good. But the high amount of slow, sharp corners make me go "BLAH!" 6 out of 10.
Madrid. Absolutely beautiful. Maybe including a longer straight could make it better but a 10 out of 10 otherwise.
The Portuguese need their GP back. But not here. Disgusting describes a 3 out of 10 here. Too long, too many corners, only 2 good straights.
Athens is good, but it has that twisty factor in there that makes me downgrade it. Too many bends in the first few km. 6 out of 10.
Birmingham is perfect. 10 out of 10. Perfect amount of overtaking opprotunities mixed in with speed. Well done
9 out of 10 for London. It's actually great, but it lacks that little bit extra in my eyes. Any slight improvement would make me say "perfect!"
Knockhill is okay. It's good, but not great. 6 out of 10.
Curghburgh looks okay. But I don't see passing at a high rate here. 5 out of 10.
Felipe Baby, Stay Cool
Albert Einstein wrote:Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.
- watka
- Site Donor
- Contact:
I agree, I really like the Madrid track. Nice blend of sweepy bits and point 'n' squirt sections.
In fact, it's inspired me to come up with something for Barcelona: http://www.gmap-pedometer.com?r=6032331
Watka - you know, the swimming horses guy
watka wrote:I agree, I really like the Madrid track. Nice blend of sweepy bits and point 'n' squirt sections.
This is exactly the Montjuic Circuit used by Formula 1 in 1969,1971,1973 and 1975.
pasta_maldonado wrote:The stewards have recommended that Alan Jones learns to drive.
go_Rubens wrote:Alright Rob, you want feedback. I will give you it.
cheers for the feedback mate
next up edinburgh
http://www.gmap-pedometer.com/?r=6032821
and belfast
http://www.gmap-pedometer.com/?r=6032828
rob
EDIT
valencia
http://www.gmap-pedometer.com/?r=5769756
- go_Rubens
roblomas52 wrote:cheers for the feedback mate
next up edinburgh
and belfast
rob
EDIT
valencia
No problem with feedback, as I will express my opinion on those next three!
Edinburgh looks fast, flowing, and if I'm not mistaken, over 100 meters in elevation change? Sounds sick! A few 90 degree corners in there. Doesn't hurt! 9 out of 10.
Belfast is another 9 out of 10. It has a fast layout, unlike most street circuits. Crossover as well? Awesome.
Valencia is okay. But a track like Valencia there shouldn't be modified. It is a good circuit as is. It's the lesson I have learned when I realized I'm the front runner for the worst track in this week's competition after redesigning Brno that I'm going to say to you. When you modify a good circuit like Brno or trifle with other circuits like Oulton Park and Brands, you feel ashamed of yourself. Like me, as I was doing all of that last night 6 out of 10.
- watka
- Site Donor
- Contact:
pi314159 wrote:watka wrote:I agree, I really like the Madrid track. Nice blend of sweepy bits and point 'n' squirt sections.
That was indeed the joke. Wanted to see how quickly people would recognise it!
and now, my modern take on montjuc park
http://www.gmap-pedometer.com?r=6034653
peace out
Rob
EDIT
seville
http://www.gmap-pedometer.com?r=6034671
peace out
Rob
EDIT
seville
I can't believe this thread has been in the wrong forum for almost 4 years. I'm moving it to the Eric van de Poele Memorial Forum, if anything to justify my salary
- watka
- Site Donor
- Contact:
roblomas52 wrote:and now, my modern take on montjuc park
peace out
Rob
EDIT
seville
I like both a lot! Not conventional street circuits and the park settings are nice!
watka wrote:roblomas52 wrote:and now, my modern take on montjuc park
peace out
Rob
EDIT
seville
Cheers mate
more tracks
Rafeala, argentina
http://www.gmap-pedometer.com?r=6036955
the closest f1 will get to an indycar race
Basingstoke
http://www.gmap-pedometer.com/?r=6036952
an indy car circuit that goes arround my local area
Rafeala, argentina
Basingstoke
hockenheim it is, today
http://www.gmap-pedometer.com?r=6039325
supposed to blend the old track with the new
peace out
Rob
peace out
Rob
roblomas52 wrote:hockenheim it is, today
peace out
Rob
Meh. Doesn't bring the character of old Hockenheim back. And who needs 4 arena sections? One motodrome is enough.
I'd suggest the following track for Hockenheim: http://www.gmap-pedometer.com/?r=6039343
The idea is basically to bring the character of old Hockenheim back without cutting down too many trees, and keeping a hairpin for overtaking.
or:
current first corner
old long straight
old chicane turn 2-3
next long sweeper
ostkurve chicane(for some ballsy downhill passing)
next long straight
'82-91 rounded chicane
straight into the current Mercedes Arena
then the Old Stadium section
ALSO: plant some dang trees where there aren't grandstands/accommodations. don't clear out an air-field sized chunk of forest, plant trees over the old track which doesn't have nearly the same surface area, and call yourself a conservationist, Ecclestilke.
old long straight
next long sweeper
next long straight
I believe in German BARawnda-Tyrrell-Simca(and it's working)
the only difference between the roman gladiators and racing drivers is that racing drivers sit inside the lion that is trying to kill them.
- go_Rubens
I will go the path of Rob and ask for feedback on this set of tracks:
What Silverstone may look like when an idiot redesigns the course http://www.gmap-pedometer.com/?r=6040218
Buenos Aires made better, and faster http://www.gmap-pedometer.com/?r=6040226
A street circuit in Paris http://www.gmap-pedometer.com/?r=6040228
Augsburg, home of one of the most famous whitewater slalom courses in the world, gets its street circuit! http://www.gmap-pedometer.com/?r=6040235
Oulton Park may now be suitable for a GP again http://www.gmap-pedometer.com/?r=6040243
go_Rubens wrote:I will go the path of Rob and ask for feedback on this set of tracks:
i felt your discription of Silverstone was good
I didnt like the last 3 corners at buenos aries because i personally felt they were a bit tight.
paris looked pretty cool and very fast
ausburg looked a little bit meh in my mind because of the tight corners
Oulton park is fine as it is right now IMO but at least you kepd Druids which is where Danny Watts famousley crashed a formula renault car in 2001.
my take on silverstone Stowe having redesighned it for the BTCC
http://www.gmap-pedometer.com?r=6040597
a faster version of monza with a 1.6km pit straight
http://www.gmap-pedometer.com?r=6040605
an improved abu dhabi
http://www.gmap-pedometer.com?r=6040612
basingstokes take on avus
to quote the ancient philosipher jmaes may
Oh C**k
peace out rob
- go_Rubens
roblomas52 wrote:my take on silverstone Stowe having redesighned it for the BTCC
peace out rob
Cheers for the feedback, mate!
Stowe looks okay. Kinda like the old Interlagos where it just twists back and forth and keeps doing it, which is a cool feature most racing tracks don't have. But the circuit overall is a meh. A lot of the corners are hairpins.
Monza should never be trifled with. You see, it is a classic, and should only be modified for safety at best. But despite this, it is a good layout. A bit concerned about the entrance to the Curva Grande.
Abu Dhabi is another meh. Keep the flow going with the first 5 turns, but I don't like the 3 hairpins, nor the fast kink in the straight. Keeping the rest of it intact was something I was okay with.
Rob, the last track has the same web address as Abu Dhabi and looks nothing like England, so tough luck on the last one, mate.
More circuits. Please give feedback:
http://www.gmap-pedometer.com/?r=6041049 Wurz has infected this street circuit in Pittsburgh.
http://www.gmap-pedometer.com/?r=6041067 Pocono Road Course redesign.
http://www.gmap-pedometer.com/?r=6041116 Imola gets the chicane kicked out of it.
http://www.gmap-pedometer.com/?r=6041125 A track in Switzarland.
http://www.gmap-pedometer.com/?r=6041134 There is a reason to call this track Koti Kimi Raikkonen.
go_Rubens wrote:roblomas52 wrote:my take on silverstone Stowe having redesighned it for the BTCC
peace out rob
More circuits:
pittsburgh was pretty cool
Didn't really like pocono that much especially when one considers that it has a bigger infield area than Indy
imola was really cool, so was the swiss and finnish tracks
basingstoke avus with the corect web adress!!!
http://www.gmap-pedometer.com/?r=6040626
Gibraltar
http://www.gmap-pedometer.com?r=6041175
yes that is a road crossing the main airport runway
more from me today
torquay
http://www.gmap-pedometer.com?r=6046751
a proposal for hockenheim
http://www.gmap-pedometer.com/?r=6046137
and another proposal
http://www.gmap-pedometer.com/?r=6046352
ebisu
http://www.gmap-pedometer.com/?r=6046175
peace out
rob
torquay
ebisu
peace out
rob
more crap from my backcatalog
mexico city
http://www.gmap-pedometer.com?r=6060625
new york
http://www.gmap-pedometer.com/?r=6046907
long beach
http://www.gmap-pedometer.com/?r=6047376
zagreb
http://www.gmap-pedometer.com/?r=6049093
glasgow
http://www.gmap-pedometer.com/?r=6054381
sparsholt collage
http://www.gmap-pedometer.com/?r=6053034
jakarta
http://www.gmap-pedometer.com/?r=6049035
designed with WTCC and indy cars in mind
peace out
rob
mexico city
new york
long beach
zagreb
glasgow
sparsholt collage
jakarta
peace out
rob
I like your track and it reminds me of the circuit on Forza 3. Was that the idea?
Anyway, using street view on Google Maps it seems as though some of your Central Park routes were a bit narrow and it would be like Monaco.
Speaking of Central Park, I love that line from Die Hard: With A Vengeance when J. McClane rushes down Manhattan in a taxi to stop a bomb going off and takes a shortcut.
"I didn't say Park Drive, I said through the Park" Those who have watched that film should know what I mean.
Check out the position of the sun on 2 August at 20:08 in my garden
Allard Kalff in 1994 wrote:OH!! Schumacher in the wall! Right in front of us, Michael Schumacher is in the wall! He's hit the pitwall, he c... Ah, it's Jos Verstappen.
yes it was
- go_Rubens
More feedback Rob.
Autodromo Hermanos Rodriguez is good as is, but the chicane ensures the Pereltada can be run safely at fast speeds the way it was meant to be run. 9 out of 10.
New York is decent, but roads through Central Park would not work, as they are probably as narrow or even narrower than Monaco. What motor racing fan wants that? 7 out of 10.
Long Beach is a 9 out of 10. The new section increases the length of the straight while being complex and the track character seems to be there.
Zagreb looks awesome. It is on a hillside with elevation change. It is fast. It has overtaking opportunities. 9 out of 10. It lacked that little bit extra in it.
Glasgow is great as well. The first corner looks to be about 270 degrees. When do you see corners like that? Shanghai, but this is much better than Shanghai. 10 out of 10.
Sparsholt. Fast and has overtaking opportunities. Just like Zagreb, but with faster corners. As a result, a 10 out of 10 comes your way.
Jakarta is bad. It has straights, but there are too many damn chicanes and tight bends. Not appealing to me. 3 out of 10.
More tracks to come here. Feedback please:
Mosport
http://www.gmap-pedometer.com/?r=6061072
Le Mans Bugatti
http://www.gmap-pedometer.com/?r=6061080
Staten Island
http://www.gmap-pedometer.com/?r=6061086
Chicago
http://www.gmap-pedometer.com/?r=6061087
Ajaccio
http://www.gmap-pedometer.com/?r=6061093
Ottawa
http://www.gmap-pedometer.com/?r=6061098
Bourg Saint Maurice
http://www.gmap-pedometer.com/?r=6061102
Mosport
Le Mans Bugatti
Staten Island
Chicago
Ajaccio
Ottawa
Bourg Saint Maurice
Mosport was pretty cool but i'm not sure on the section between 1km-2km 8/10
Le Mans looked cool and quite ballsy 9/10
I wasn't really that fussed on the Staten Island track 6/10
Chicago looked awesome 9/10
Corsica was like Chicago only more so 9.5/10
Ottowa was not my cup of tea in tearms of design 5/10
Bourg Saint Maurice was awesome 10/10
some more from me now
seoul
http://www.gmap-pedometer.com/?r=5792715
Pyonyang
http://www.gmap-pedometer.com/?r=5796123
Macau
http://www.gmap-pedometer.com/?r=6062248
Jerusalem
http://www.gmap-pedometer.com/?r=6062271
Qubec
http://www.gmap-pedometer.com/?r=6062238
Thruxton
http://www.gmap-pedometer.com?r=6062859
Rob
seoul
Pyonyang
Macau
Jerusalem
Qubec
Thruxton
Rob
- go_Rubens
Here's one for you: http://www.gmap-pedometer.com/?r=6063882
Rob, I'll give feedback. But I need to think first
- dinizintheoven
go_Rubens wrote:Here's one for you: http://www.gmap-pedometer.com/?r=6063882
I see what you did there.
James Allen, on his favourite F1 engine of all time:
"...the Life W12, I can't describe the noise to you, but imagine filling your dustbin with nuts and bolts, and then throwing it down the stairs, it was something akin to that!"
- go_Rubens
dinizintheoven wrote:go_Rubens wrote:Here's one for you: http://www.gmap-pedometer.com/?r=6063882
Since Silverstone and Thruxton look fairly similar and the runways are set up similarly, I felt an improbable urge to design that.
