And here are the results:
14.
More_Blue_FlagsMost of it is just 90-degree corners and long straights. I'm sorry to say that this track just doesn't inspire too much.
13.
AdrianBelmonte_This one is very tight and twisty, maybe even too tight and twisty. Apart from the main straight it's just corner after corner with few overtaking opportunities.
12.
Warren HughesIt looks better than Baku and even at that Baku isn't the worst track in the world. But again it's mostly 90-degree corners and long straights. There are some good corners besides though. I've definitely seen worse street circuits in real life.
11.
tommyklI just knew someone was going to do Baarle-Hertog! A nice, relatively quick circuit when taking its length into account.
10.
mrfakeboullierI did warn against doing really long circuits! But I suppose if I really wanted to stop people from designing them I would have set a maximum length. Anyway, this isn't a bad circuit. It's really fast (mostly). My only real gripe would be that the section between 3 and 4 km has too many slow corners that break the flow. Other than that, good effort!
9.
BleuUsing the same location as AdrianBelmonte_ (and in places, the same layout), this one has a bit of old Hockenheim going on, only the technical section takes up much more of the track's layout. This would make a real nightmare for setups.
8.
peteroli34Lots of 90-degree corners, but it's not totally without variety. The long right-hand kink between 4 and 5 km reminds me a little of Long Beach. The entry to the hairpin about halfway between 2 and 3 km also looks very tricky. Good job.
7.
SamsterThe right-hander between 2 and 3 km looks like a challenge to take flat-out, so the chicane before it seems to be well-placed for this purpose. Very good track overall.
6.
watkaI like the long-radius first corner and, well, the track in general looks pretty good!
5.
dr-bakerThis is one fast circuit. You didn't go full AVUS this time, and with good results.
4.
BenettonThis looks like it could be quite a picturesque track, and it does indeed appear to offer a setup dilemma. Good job.
3. tBoneA very nice, fast circuit. Lots of large radius bends that remind me a bit of the old Fuji.
2. UgncreativeUsergnameThe fastest part of the track has tight corners to create overtaking opportunities, while the slower part is made up mostly of great sweeping bends. Mostly, it has a great flow to it. Nice job.
1. BiscioneI can see where you're coming from with the Macau comparisons. Lots of elevation changes and a combination of fast and slow sections have made for one epic street circuit. Well done!
