SuperAguri wrote:As I got the answer right I am going to put in a trivia question...
F1 has had a lot of engines from inline/straight, flat, V, W, H, turbine, inline turbo and v turbo in various cylinders from 4 to 16. However which raced (as in at least qualified) configuration of engines have not won a F1 race (and what was their best position...) for example the V8 has won races so you can ignore that.
When you talk about the engine configuration, do you treat normally aspirated and forced induction engines separate? The architecture of a forced induction and normally aspirated engine is quite different, after all. Also, the Lotus 56B with the gas turbine has been mentioned - would that be eligible, or are you looking only for conventional piston engines?
Either way, I'll give it a go and see if some of these might be right:
[Alfa Romeo Turbocharged V8 (1.5L)- 2nd place in the 1983 German GP and 1983 South African GP.]
Alta Straight 4 (2.5L) - 9th place in 1950 Belgian GP.
Aston Martin Straight 6 (2.5L) - 6th place in the British and Portuguese GP's, 1959.
BRM Supercharged V16 (1.5L) - 5th place in the 1951 British Grand Prix.
ERA Supercharged Straight 6 (1.5L) - 6th place in British and Monaco GP's, 1950.
[Gordini Straight 4 (1.5L) - 4th place in the 1950 French Grand Prix.]
Gordini Straight 6 (2.0L) - 3rd place in the Swiss and Belgian GP's, 1952.
Porsche Flat Four (1.5L) - 2nd place in the French, Italian and US Grand Prix's in 1961.
[Pratt and Whitney Gas turbine (unknown turbine blade size) - 8th place in the 1971 Italian GP]
Scarab Straight 4 (2.5L) - 10th place in the 1960 US GP.
Tecno Flat 12 (3.0L) - 6th place at the 1973 Belgian GP.
[] indicate a speculative
Perhaps this might do as a start?
DanielPT wrote:stupot94 wrote:But I go flat 12
Sorry to disappoint again, but Niki Lauda won his first championship in a Ferrari Flat-12 engine. It was 3 liters though...
Was it? I've seen some say that the architecture of the Ferrari 12 cylinder engines from the 1970's were not true Flat 12's, but in fact should be considered as a V12 engine with a 180º bank angle.
This is a picture of the Ferrari Tipo 015 engine, as used in the 1975 Ferrari 312T, before use in the 1975 BRDC International Trophy at Silverstone that year. As you can see, the cylinders are actually not directly opposed each other, but are actually slightly inclined to the horizontal plane.
![Image](http://farm3.static.flickr.com/2558/3884412124_8f22c586c4_b.jpg)
Taken from this particular photo album on flickr:
http://www.flickr.com/photos/37692943@N07/3884412124/Technically speaking, therefore, I would argue that it is wrong to classify the Ferrari 12 cylinder engine from the 1970's as a Flat 12 because the piston motion is not solely in the horizontal plane.
