I'd love to see either David or Matthias start the race at Brands Hatch, as we've given away nearly 30 free tickets to our fans to watch us at 'home'."
Fixed. Brands Hatch tickets aren´t given away THAT cheap!
Tread lightly in ARWS. Every decision might be your last.
Scuderia Alitalia welcomes F1RWRS Commission decision Scuderia Alitalia team principal Alasdair Lindsay has shown a rare sign of support for the governing body of the F1RWRS commission. It comes after vehement protests from both his own team and Team Phoenix against MRT's attempts to obtain documents regarding Castrol Jones Racing's technical and financial details.
"I must thank the F1RWRS commission for seeing sense on this issue," said Lindsay. "MRT have been waltzing around the place like they think they are bigger than the sport. Perhaps this will change their tune for once. The details of CJR should remain solely in the hands of CJR. I would not expect such a sensible decision from the likes of the FIA though, it's just as well we are not under their juristiction."
Lindsay strongly denies rumours he is attempting to get cosy with the series' governing body in an attempt to persuade them to give an exception to the four driver rule.
Cor, that's a bit strong
RIP NAN - 26/12/2014 RIP DAD - 9/2/2015
Currently building a Subaru Impreza to compete in the 2016 MSV Trophy. PremierInn spokesperson for Great Ormond Street Hospital
If it hasn't occurred to you yet, I'm playing the role of the early 2000s Ferrari, trying to bend or even break the rules whenever I see fit and mostly getting away with it
Wizzie wrote:If it hasn't occurred to you yet, I'm playing the role of the early 2000s Ferrari, trying to bend or even break the rules whenever I see fit and mostly getting away with it
My proposal to form a brand-new team to replace the failure that Team Phoenix was being and shortcut my way to success was rejected straight away No matter, I'm sure I'll turn things around and it'll be more exciting this way.
The main determining factor for success in the F1RWRS is engine power. You just need to be able to afford a half-decent engine and you'll be fine. Hell, Foxdale, HRT, Jones and Sunshine could be in the exact position as MRT if they'd gotten to the Zakspeed engine first. It doesn't matter how good or bad the chassis is (Well, it does matter to an extent with the power limit that each chassis can handle which is why the Dagnall cars are slower than the MRTs), success or failure basically depends on how much power you can extract out of that engine
In which case...
VETO THE P-87S!!!!!!
Phoenix wrote:I remember I chose my package looking for a well-balanced package that would have no vices. How wrong my theories were...
I chose my 2013 package based on a car, whilst not the fastest in a straight line, would be quick around tighter circuits. Instead, I ended up nearly getting ROTY for my troubles
Phoenix wrote:My proposal to form a brand-new team to replace the failure that Team Phoenix was being and shortcut my way to success was rejected straight away No matter, I'm sure I'll turn things around and it'll be more exciting this way.
In which case...
MRT won't be running the P-87 next year if it's approved. BMW already have a P-90 in the works because they can
I thought about having a car that would both handle well and have a decent amount of power, since I assumed no one was going to have enough credits to make a perfect car and Aristotle came down to me for advising. Instead, I scored a paltry 2 points and failed to even prequalify after mid-season in all races. I'm still trying to recover...
Little side story now: With O'Lauchlan now back in the F1RWRS, the exploits of both him and Reyna-Sanchez in the IndyCar series have come to light. O'Lauchlan is currently 6th in the IndyCar points standings with one second and a host of top 10 finishes while Reyna-Sanchez is third having (somewhat fluked) his way into the Indianapolis 500 victory ahead of Will Power and James Hinchcliffe) and is behind Hinchcliffe and Tony Kanaan (in what may prove to be his final season) in the championship
Wizzie wrote: The main determining factor for success in the F1RWRS is engine power. You just need to be able to afford a half-decent engine and you'll be fine. Hell, Foxdale, HRT, Jones and Sunshine could be in the exact position as MRT if they'd gotten to the Zakspeed engine first. It doesn't matter how good or bad the chassis is (Well, it does matter to an extent with the power limit that each chassis can handle which is why the Dagnall cars are slower than the MRTs), success or failure basically depends on how much power you can extract out of that engine
That´s not entirely accurate. A bad chassis can make you lose up to 40bhp of your allocated engine power, it also can make you gain a little bit so it´s an important decision. It also affects your drivers consistency quite a bit. What´s wrong with the people is the approach regarding "having a slow car but good at slow tracks"; for that what you actually have to do is to have a good chassis and then invest money in your drivers, instead of burning 1000 credits in a chassis-engine combination.
40bhp isn't that much when you're at least 120bhp up on most of the field anyway
Which isn´t to happen anymore As I published before, there´ll be the tendency that the new engines coming will be at least 680 bhp and no engine will be able to be developed past 810 bhp, so that we shift in a two/three season period the whole field into more levelled power outputs. Prices will be revised as well to ensure teams can move up and then we´ll be able to lower random grip ratings to a 1000-1600 starting range.
Aerond wrote: That´s not entirely accurate. A bad chassis can make you lose up to 40bhp of your allocated engine power, it also can make you gain a little bit so it´s an important decision.
Ah shite. That means I'm gonna have to be on have to be on my A-Game again behind the scenes at MRT
Sweet. I can dump the crapboxes I've been using without resorting to a second pay driver
Perhaps this might benefit Sunshine... Hum....
But what I tried to do was to have a car that would be performing adequately at all kinds of circuits, with a decent turn of reliability In the end I got neither.
With Dean O'Lauchlan, one of Daniel Melrose's many friends in the world of motorsport, back in the F1RWRS with HRT, rumours are floating around that Melrose may be looking at a move to the team in 2015 after allegations that the Australian pulled some strings to the the IndyCar driver and former dirt racing champion to get him the second HRT seat. While Melrose has publicly stated on many occasions that his priority is to stay in the Jones Racing Team, rumour has it that he's looking at alternative options including HRT and the proposed Simpson Motorsport outfit. Neither Melrose, Jones or HRT Boss Mark Skaife were available for comment.
Ridiculous. If he keeps jumping from team to team he's bound to get bored and leave the sport all together!
Mistakes in potatoes will ALWAYS happen Trulli bad puns... IN JAIL NO ONE CAN HEAR YOU SCREAM
Well people have said that the guy has almost seemed "lost" since leaving MRT or possibly ever since he left his "personal playground" (i.e. Formula One) and some are theorising that teaming up with best friend Davies might just be the key to getting the absolute devastating best out of Melrose (Right now, he's probably at about the same level as he was in 2008 and yet he's still one of the best drivers out there)
I´m sorry but I haven´t found the time this weekend to make the British GP happen. Will do as soon as possible, but I´ve been busy in my free time due to the fact I´m playing right now in not one, but two projects, being the 2nd an artist under contract and many gigs coming.
Aerond wrote:I´m sorry but I haven´t found the time this weekend to make the British GP happen. Will do as soon as possible, but I´ve been busy in my free time due to the fact I´m playing right now in not one, but two projects, being the 2nd an artist under contract and many gigs coming.
I for one would love to know when and where those gigs are (Although being on the other side of the world means I can't attend them myself)
Haha, all of them in Spain. For the moment is three in Madrid, then Burgos, Segovia and Vigo, probably followed by another one or two in Galicia and a tour around northern Spain around Eastern.
Aerond wrote:Where are you in, phoenix? I can tell you whenever I come close to your place
As Wizzie said, I'm from Majorca, but I'm currently in Madrid, where I'm doing my degree.
On 9th February I play Joy Eslava with Bravo Fisher (Electro-Pop) and on 11th February I play El perro de la parte de atrás del coche with Niño Burbuja (which is the project I recorded the album with recently)
I can't go on the 9th because I have an exam on the 10th and will need revising, but chances are I can go on the 11th. Where's the place you're going to play that night?
Phoenix wrote:I can't go on the 9th because I have an exam on the 10th and will need revising, but chances are I can go on the 11th. Where's the place you're going to play that night?
It´s Corredera Baja de San Pablo esq. Calle Puebla (nearest metro is Gran Via). If you come say hi!
Phoenix: "Hey guys, I've got a mate whose playing a gig tonight, want to come?" Phoenix's friends: "Yeah sure, who is it?" Phoenix: "Well, I know him on the internet..." Phoenix's friends: " "
Nico Rosberg wrote:Break me down mentally? Good luck with that one.
Warren Hughes wrote:Phoenix: "Hey guys, I've got a mate whose playing a gig tonight, want to come?" Phoenix's friends: "Yeah sure, who is it?" Phoenix: "Well, I know him on the internet..." Phoenix's friends: " "
Phoenix and friends? Something is wrong with that picture... Just kidding, of course.
I've never been there, but I've quick-checked in Google Maps and it's not actually very far from where I am (close to Ciudad Universitaria). At which time are you playing? And is there anything else I need to know? (i.e. having to buy a ticket to enter, booking, etc.)
