Cars
Not too much has change in this respect, if at all. We will still use the Jones-Holden combo used in 2018.
Car: Jones 115
Engine: Holden LSF3-18
Drivers
For those of you who have ever looked at the driver market in the Alt-F1 Current Era, the system will not be unfamiliar to you. Basically you pick drivers and the gods of RNG decide in case of a real-life driver and the users decide for their fictional drivers. There are no general limits for entry in Formula 3.
Contracts are generally one-year and may be canceled by either side without stating reasons with one weekend notice. Other agreements are possible between users and DEC owners.
As you may have realised from the first paragraph of this part, real-life drivers are permitted in the series. Please note that this is Formula 3. Most any driver that has driven a car in the same level is very likely to reject your offers.
If you enter a fictional driver, I may reserve the right to question you why the driver is doing Formula 3, if I consider him, due to his past experience, too advanced to do F3. Should I find your answer to that unconvincing, your driver will be banned from taking part in the F3 Eurasian Championship.
Teams
Entries will be expanded to 12 teams, from the 9 in 2018. The priority list will be kept from last year for new teams:
a) New teams from users that have not run a team in any of ARWS, AR3.5, AR2.0, Alt-F1, F2, F3 last season
b) Teams from AR 2.0 that want to change serieses
c) Other teams
The top 2 of 2018 can run a third car should they want to. The third car won't be elegible to the WCC tally of the team. Should they chose not to run the third car, the privilige is passed on down the order.
To enter, please fill out the following formula.
Code: Select all
Team Name: Duh...
User:
Nationality: Only one nationality, all UN member states + Palestine are permitted
Car Numbers: Any two consecutive numbers from 3-120, with the exception of 4, 13, 17 and 69.
---- First Driver ----
Candidate:
Nationality:
DEC User:
---- Second Driver ----
Candidate:
Nationality:
DEC User:
If you aim to sign a real-life driver, please post a few more options to make sure you are not without a driver when the season starts.
Race Weekend
There will be ten weekends of two races of 70 km on each weekend with a seperate qualifying session for each. In addition to that, there will be two special events; the Pau and Ansan SuperPrix, both run at 80 km.
Points will be awarded in accordance with the new F1 points system for 2018:
1 - 15 pts
2 - 12 pts
3 - 10 pts
4 - 8 pts
5 - 6 pts
6 - 5 pts
7 - 4 pts
8 - 3 pts
9 - 2 pts
1 - 1 pt
Pole Position - 2 pts
Two cars of each team can score points in the team championship. For violation of the sporting regulations, drivers will be assessed penalty points. Any driver that amasses 10 penalty points will lose his team 6 points in the team championship.
