I've encountered some strange glitch - for lack of a better term. Since I've returned, the website logs me out on its own after a certain amount of time, despite me being "logged on automatically". At first it didn't happen too often, but since a few days ago I can't stay logged in for longer than a couple of seconds.
It kicks me out when I click on a different subforum, it kicks me out when I try to post stuff, it kicks me out when I click on the preview button before posting, it even kicks me out when I do nothing at all.
FAQ suggests that it could be because of my 4 years of inactivity. But I suppose it could also be that I've caused a glitch by updating parts of my profile recently and clicking on something I shouldn't have clicked on. Wouldn't put that past me...
Since I have no trouble with any other forum I'm subscribed to, and since I can't be the only one using IE, chances are the glitch lies somewhere within the GPRejects forum coding.
Thank you in advance for looking into this!
Login Trouble
- DemocalypseNow
- Contact:
Re: Login Trouble
Turbogirl wrote:Since I have no trouble with any other forum I'm subscribed to, and since I can't be the only one using IE, chances are the glitch lies somewhere within the GPRejects forum coding.
Hello,
Cookie settings use a universal code which is supported by IE11. We don't promise any compatibility with IE versions earlier than IE11, as Microsoft no longer supports these.
I would suggest purging your cookie and cache data for gprejects.com by following the instructions located here.
Also, give another browser like Chrome a try for a day or two and see if the issue also occurs there.
Re: Login Trouble
DemocalypseNow wrote:Hello,
Thank you so much for your quick response!
![Smile :)](./images/smilies/icon_e_smile.gif)
I'm using IE11, so that can't be the problem (thank god). And after I did the purge, things seem to be normal again. I've been logged in this morning for more than 20 minutes, clicking on subforums and posts like a crazy person, without encountering the glitch a single time.
EDIT: Make that 2 sessions of more than 20 minutes, including posting a rather long and complex announcement. That should mean I'm safe from the glitch, right?
Weird, but satisfying. Must be one of those once-in-a-lifetime-glitches then. Should it happen again, I'll try out one of the other browsers.
Thanks again for your help! See you around!
- DemocalypseNow
- Contact:
Re: Login Trouble
Turbogirl wrote:Weird, but satisfying. Must be one of those once-in-a-lifetime-glitches then. Should it happen again, I'll try out one of the other browsers.
No problem! It sounds like there was a mismatch between your cache information and our database's session information. If it happens again, always try clearing cache and cookies before anything more drastic!
[Moving to closed tickets]
